Armor/AFV: Modern Armor
Modern armor in general.
Hosted by Darren Baker
Building the Bergepanzer 2 from Takom
47jw66
KitMaker: 19 posts
Posted: Sunday, August 04, 2019 - 05:53 AM UTC
Far from boring, Donald!!
varanusk
Santa Cruz de Tenerife, Spain / España
KitMaker: 1,095 posts
Posted: Monday, August 05, 2019 - 01:36 AM UTC
Agree, thanks for the effort and time you put here, it is really interesting
OldWarloke
KitMaker: 2,336 posts
Posted: Monday, August 05, 2019 - 09:15 AM UTC
Today I joined the Upper & Lower Hulls together.
a little filling and sanding is needed here, as there's no skirting to cover this area.
OldWarloke
Posted: Monday, August 05, 2019 - 09:19 AM UTC
The Winch door may be positioned in the open or closed position.
I chose the closed position, as this wouldn't be open unless you were using the winch . It wouldn't be open for travel or when using the crane. Besides there's no cable or fittings for it.
Next I think I'll be doing some painting.
That's all for a while.
Donald
joepanzer
KitMaker: 735 posts
Posted: Monday, August 05, 2019 - 12:10 PM UTC
Awesome detailed description!
Don't worry about people that could get bent about your technique.
Did the Medecis stand over Michaelangelo's shoulder and complain?
DarthLetcherous
KitMaker: 22 posts
Posted: Monday, August 05, 2019 - 12:30 PM UTC
Fantastic. Love the step by step. Gonna make my build a breeze. Thanks.
OldWarloke
Posted: Tuesday, August 06, 2019 - 09:38 AM UTC
I hope you like my step by step for painting the Wheels
First while still on the Sprue I painted the outside Nato Green and the inside areas Model Master Steel, this will give the rub area.
Next I painted the Lower Hull Nato Green.
After removing the Wheels from the Sprue and cleaning them up I mounted them on toothpicks then painted the edge with the Tire Color.
OldWarloke
Posted: Tuesday, August 06, 2019 - 09:46 AM UTC
Followed by the outside edge.
Then the surface.
All ready for assembly and Installation .
Next to Install the Wheels and then start on the Track.
Done for now.
Donald
OldWarloke
Posted: Wednesday, August 07, 2019 - 12:42 AM UTC
This has been posted also as a correction for earlier in the build.
Donald
OldWarloke
Posted: Wednesday, August 07, 2019 - 10:04 AM UTC
Here's the Blade I hope this is self explanatory .
If by chance you do get the Mounting Arms installed upside down rather than tearing every thing apart you could Just rotate the mounting plates (maby no one will notice).
OldWarloke
Posted: Wednesday, August 07, 2019 - 10:11 AM UTC
I got distracted with the Blade, I just realized that I could have installed the Blade Mounts upside down that would have complicated everything , luckily I had them right.
This was to maby keep any of you from making the mistake
Maby now on to the Wheels and Track
Donald
Tank1812
KitMaker: 785 posts
Posted: Wednesday, August 07, 2019 - 10:30 AM UTC
Nice recovery. Thanks for posting the tips.
bison126
Correze, France
KitMaker: 5,122 posts
Posted: Wednesday, August 07, 2019 - 10:42 PM UTC
Thanks for all the useful tips.
By the way the extra sprocket wheels feature different hubs. They are not the same you used on your model.
Olivier
OldWarloke
Posted: Thursday, August 08, 2019 - 06:51 AM UTC
Olivier
I used the ones called fore in the instructions, just wanted to point out that there were different ones in the box
Donald
OldWarloke
Posted: Thursday, August 08, 2019 - 06:52 AM UTC
Have the Wheels assembled and installed .
No Poly caps on the Wheels, so they will be glued eventually .
Painting before assembling the Track, that's coming up when they'r done
Regards.
Donald
flugwuzzi
Lower Austria, Austria
KitMaker: 611 posts
Model Shipwrights: 23 posts
Posted: Friday, August 09, 2019 - 12:36 AM UTC
Phantastic build blog, Donald!
Thanks for adding all the useful information, very appreciated.
Walter
ironhull
Venezia, Italy
KitMaker: 125 posts
Posted: Friday, August 09, 2019 - 03:14 AM UTC
The V sprues come from Gepard it and the extra sprocket wheel is the early style with 8 bolts hubs which is correct for Gepard and earlier Leopard. The Bergeleopard kit has the later style with 15 bolts and this is correct for most Bergeleopard (and later Leopard) except for the initial batch. For exaple Italian Army bought 127 Bergeleopards in two batches and the first come from Germany, other beeing built in Italy under license by OTO Melara. All German made Bergeleopards had the 8 bolts hub, the others 15 bolts. During their service some tank from the first batch had the later wheel because they were totally interchangeable.
Reforger-Victim
Hessen, Germany
KitMaker: 69 posts
Posted: Friday, August 09, 2019 - 08:40 PM UTC
I ll be waiting for an interior kit to come for sure..
OldWarloke
Posted: Sunday, August 11, 2019 - 02:33 AM UTC
I finally have the Track Links painted.
I sprayed all the parts with Model Master Gun Metal paint, then cut the Sprue into easy handle strips to make it easier to hand paint the rubber pads. This is very tedious painting.
Now it's ready for assembly.
That's all for now.
Donald
BlackWidow
European Union
KitMaker: 1,449 posts
Posted: Sunday, August 11, 2019 - 03:32 AM UTC
Donald, good progress so far. I'll watch your build with big interest as this kit is on my wish list for years and years. So I hope old Santa will listen closely to this posting ....
I have some nice memomries of the "Bergeleo" during my active time, especially that 4. January 1989 still leaves a smile on my face when I needed the help of one of these from our recovery unit to get my truck out of deep mud - after 6 hours waiting for it. It took only 15 minutes then but we were all covered with mud, especially me ....
Enjoy the build!
Torsten
Removed by original poster on 08/14/19 - 06:37:59 (GMT).
barkingdigger
#013
KitMaker: 3,633 posts
Posted: Sunday, August 11, 2019 - 09:11 AM UTC
I'm watching with interest, as this berge is on my to-get list! My method of painting leo-style tracks is to spray them with a red-brown base coat, then a thinned earth colour, followed by gentle dry-brushing of the outer rubber pads with a rubbery black. From what I've seen they are always dirty or at least the metal oxidizes to an earth-brown colour, unless of course it's fresh from the wash rack and still dripping. On the inner side the middle strip of the pad is rubber (as Mike says) and the outer ones are metal, but I don't bother trying to paint the rubber strip. Instead I dry-brush alternating layers of earth (for the ground-in dirt) and rubber-black (for all the tire rubber that gets worn off on the track) along the direction of travel to simulate the way the wheels leave their mark on the track. Hope this helps! (And can't wait to hear how you cope with all those guide teeth and end connectors!)
OldWarloke
Posted: Monday, August 12, 2019 - 05:17 AM UTC
On the inside face of the tracks, only the centre panel is rubber, not the whole thing.
You are Correct, I have corrected it on the Track Links.
Donald
Here are the Pics.
Now unless something else comes up I should be able to start assembling them.
Donald
Reforger-Victim
Hessen, Germany
KitMaker: 69 posts
Posted: Monday, August 12, 2019 - 06:14 AM UTC
Finally out:
Perfect Scale's
Interior for TAKOM´s Bergepanzer 2 Standard (2122) with decals.
https://www.perfect-scale.de/de/www-perfect-scale-de-3/Inneneinrichtung-Bergepanzer-2-Standard.html?XTCsid=5vuvi1iit7i7u5h7ac14rae4l5
KitMaker: 5,734 posts
Model Shipwrights: 62 posts
Posted: Monday, August 12, 2019 - 06:45 AM UTC
Some inspiration for painting those tracks
http://data3.primeportal.net/recovery/ulrich_wrede/bergepanzer_2-y_740_172/images/bergepanzer_2-y_740_172_14_of_16.jpg
Image borrowed from
http://www.primeportal.net/recovery/ulrich_wrede/bergepanzer_2-y_740_172/
where there are more images
