Painting brass/copper surfaces
Removed by original poster on 06/09/19 - 05:54:38 (GMT).
KitMaker: 2,006 posts
Model Shipwrights: 1,501 posts
Posted: Friday, May 24, 2019 - 07:06 AM UTC
Hi,
Thank you for the response. The thing is I was not asking about paints - I was thinking about technique. As I said scale effect means if I simply paint it brass/copper it would look like a shiny little toy. (Real metal surfaces do not look extremely shiny when looked from afar, unless they are polished to a high sheen. I am not certain the Nautilus would be polished...)
So I was wondering about the application of paint.
Hi Andras,
First off, it is cool that you are doing the Pegasus Nautilus - I have that kit in my stash too, and it looks to be a beauty!
As for the application of a “brass” effect, I would start by priming the built ship with black enamel to provide a “shadow” base. Then, apply a misted (but fairly thoroughly covering) coat of gold/brass acrylic paint, perhaps cut with a little flat gray or brown to dull it down. This should be mostly airbrushed from above to leave hints of little dark shadows beneath the rivets and other surface details. Then give the ship a wash of thinned Burnt Umber (a dark brown) artist’s oil paint, as brass tends to oxidize to a dull brownish-gold hue. I recommend artist’s oils because they are finely ground pigments, will not react with the acrylic base color, and in addition to outlining details will leave a nice filter effect to “brown down” the brass overall. I’d also add a second, lighter wash with dull, pale green oils to depict the oxidation of the copper component in the brass. Some darker green can be applied as well as to suggest marine growth. After that, some very discreet drybrushed touches of your base brass color here and there would be good to emphasize the unpainted metallic look of the vessel. As a final step I’d apply an airbrushed flat to semi-gloss clear coat to blend the whole and reduce the shine to a suitably muted, scale metal patina.
I wish you the best of luck with your steampunk sub!
Biggles2
KitMaker: 7,021 posts
Model Shipwrights: 791 posts
Posted: Saturday, May 11, 2019 - 02:40 AM UTC
Alclad doesn't dry to a high gloss unless you polish it. By itself it dries to a slightly dull semi/gloss metallic. You can also airbrush a satin clear finish over overly glossy surfaces.
spongya
MODELGEEK
Budapest, Hungary
KitMaker: 2,279 posts
Model Shipwrights: 24 posts
Posted: Friday, May 10, 2019 - 07:44 PM UTC
Hi,
Biggles2
Posted: Friday, May 10, 2019 - 02:04 AM UTC
Hi,
Thank you - the paint itself is not an issue. The worry is the method of application. I think if I cover the model "properly" -as if it was a bare metal airplane- it would look unrealistic.
Anyhow I will experiment, and see how it turns out.
Best,
A
In the Alclad link there is a tutorial on how to achieve best results with the paint (primers, base coats, pre-shading etc.).
KitMaker: 7,416 posts
Model Shipwrights: 456 posts
Posted: Thursday, May 09, 2019 - 04:50 PM UTC
I have had very good results with Molten Metals:
Polished Copper
Brass
spongya
MODELGEEK
Budapest, Hungary
Posted: Thursday, May 09, 2019 - 04:44 PM UTC
Hi,
Best,
A
Biggles2
Posted: Thursday, May 09, 2019 - 03:35 AM UTC
Alclad paints are very good. They are airbrush-able out of the bottle and go on very thin and smooth. They are also hand brushable. Possible downside is that they are lacquer.
https://www.aeronautiko.com/product_info.php?products_id=12963
spongya
MODELGEEK
Budapest, Hungary
Posted: Wednesday, May 08, 2019 - 08:47 PM UTC
I am building the Nautilus model by Pegasus, and planning to build it brass. (I know Verne wrote it was steel, but I prefer the steam-punk look.)
How best paint realistic looking brass? I am worried that if I simply use paint (any paint) it will just look unrealistic. (Real brass would look flatter, duller if you look at it afar - so the model should somehow reflect it.
One option would be "fogging" brass paint over a black/dark grey base. But that's about it. How are metal covered ships painted? (The Monitor I guess is one example.)
Thank you.
