Ships by Class/Type
HobbyBoss 1/700 USS Arizona WIP
KitMaker: 306 posts
Model Shipwrights: 155 posts
Posted: Monday, October 22, 2018 - 06:31 AM UTC
Well this is my "first" actual 1/700 ship and being it is my home state, I figure I should try my best!
I am pretty excited to get this thing started and have already started separating parts for painting. Once I glued the hull together, I saw it had very nasty line going right down the thing. So this this my first attempt at using putty:
I mixed some Squadron White with some Testors glue and used a credit card to get it in all the areas. Not the nicest job, but it will sand down.
Here is the separate little pieces that will be painted flat black:
There is something very, very cathartic about taking a little break on the weekend and gluing these things together. So relaxing.
Just cutting and cleaning up the mold lines on the superstructure before adult-duties called on me.
That's all I got so far. I love every, precious moment of it.
KitMaker: 1,972 posts
Model Shipwrights: 1,494 posts
Posted: Monday, October 22, 2018 - 02:25 PM UTC
There is something very, very cathartic about taking a little break on the weekend and gluing these things together. So relaxing...
I know what you mean. As a new dad many years ago one of my favorite sources of non-baby, non-adult duty relaxation was to steal a few moments to play with plastic! You are off to a great start with your Arizona - be sure to keep us posted as you progress!
KitMaker: 306 posts
Posted: Tuesday, October 23, 2018 - 04:24 AM UTC
I really appreciate the kind words. Really helps towards the inspiration to get it done!! Also, look what the mail man brought yesterday
KitMaker: 173 posts
Model Shipwrights: 173 posts
Posted: Tuesday, October 23, 2018 - 05:01 AM UTC
Charlie: When I saw your post this morning I was thinking to myself, how is he going to get that forward part of the deck on and deal with that infernal seam. The answer is you aren't with the help of aftermarket decks. Good for you. That seam drove me so crazy years ago when I attempted to build Arizona. I finally gave up in disgust and threw it away. That was of course in the era before wood deck aftermarket products.
Oddly enough the Dragon Arizona presents the very same problem, but their Pennsylvania includes the full deck attached to the hull in one single piece.
Will be watching AZ carefully, monitoring your progress. Looking good so far, and I am sure when your finished it will be a great tribute to your State, one that I dearly love, especially the Prescott, Cottonwood, upper Verde Valley area.
KitMaker: 173 posts
Posted: Tuesday, October 23, 2018 - 05:05 AM UTC
Forgot to ask the eternal question, Dark Gray, Standard Navy Gray, Sea Blue, or Navy Blue?
With that wood deck I know what I would do, but I am very partial to the 1930's Navy. Colorful era.
KitMaker: 306 posts
Posted: Tuesday, October 23, 2018 - 05:28 AM UTC
Thanks for the kind words, man. I did notice that the deck is split for some unknown reason. The wooden deck will defiantly help that out. I take pictures at opportunity I get to work on her, so updates will be frequent.
KitMaker: 306 posts
Posted: Tuesday, October 23, 2018 - 05:29 AM UTC
Before I even got the model, I am going with the red, white and blue theme. I loved seeing the updated more-blueish ship with some of the white up top and that lovely hull red below. The red on the main guns is an added bonus.
KitMaker: 173 posts
Posted: Tuesday, October 23, 2018 - 06:11 AM UTC
Sea or Navy Blue?
I purchased an already built West Virginia in 1/1100 by Eaglemoss. She is supposed to be in Sea Blue I suppose, unlike the very few other USN models this firm has. They are in Navy Blue, and are quite accurate to prototype, Enterprise especially so. WV on the other hand stands out like a blinking neon sign. Dull coat helped a bit, but still WV, a ship I love to the extent I have a print of her passing under the Brooklyn Bridge hanging in my den, was a real disappointment color wise.
Anyway, I will be following closely, and I am sure it will turn out quite well based upon what I have seen so far.
KitMaker: 306 posts
Posted: Tuesday, October 23, 2018 - 06:40 AM UTC
Sea or Navy Blue?
I THINK I got a jar of XF18 for her. I THINK. I will have to double check when I get home.
KitMaker: 173 posts
Posted: Tuesday, October 23, 2018 - 08:52 AM UTC
Were I building her as of 7 December that is what I would use. We modelers are generally confronted with finding the "best available" solution.
KitMaker: 306 posts
Posted: Monday, October 29, 2018 - 06:34 AM UTC
So my first adventure with Squadron™ white, and I hated it.
I sanded it down and killed three Tamiya sanding sticks to which I thought was smooth. Primer showed otherwise. I took it back in and resanded it for a long spell with some sanding sticks I made. I ordered some Vallejo water based putty for the future as it seems easier to use.
That and I am pretty sure Squadron™ white will give me brain damage based on the smell.
KitMaker: 173 posts
Posted: Monday, October 29, 2018 - 07:23 AM UTC
Tamiya makes a white putty which I swear by. Squadron white or green in my opinion is worthless.
KitMaker: 1,266 posts
Model Shipwrights: 735 posts
Posted: Monday, October 29, 2018 - 10:27 AM UTC
I use Vallejo putty all of the time, really like the narrow tip. Use Squadron putty but learned a long time ago to mask the area around where you plan on applying it. Once harden it is a pain to sand, so apply only where you need to.
A good filler is the homemade stuff made with leftover Tamiya extra thin glue (that the brush can't reach) and chopped up pieces of sprue. Does a great job as a filler and easy to sand. It also drys fast.
KitMaker: 306 posts
Posted: Monday, October 29, 2018 - 11:10 AM UTC
I plan on painting over it tonight with some black and it is what it is. On my next build, I will try the Vallejo stuff.
Good point about the masking tape, really, REALLY should have done that.
Posted: Tuesday, October 30, 2018 - 01:01 AM UTC
Charlie,
I too used to use Squadron filler (it was once the best thing going), but time has definitely passed it by. There are quite a few products out there for modelers now that are much better.
The filler I usually use is simple cyanoacrylate (super glue), which I apply to seams with an X-acto blade. It dries fairly quickly, but you can also hit it with cyano accelerator to set it instantly. It dries to about the same hardness and consistency as most model plastics, can be sanded glass smooth, doesn't flake, and is very durable.
Maybe for your next project...
Posted: Tuesday, October 30, 2018 - 01:11 AM UTC
By the way, Charlie, don't worry if this project isn't perfect - they never are! We just do the best we can, learn from experience, and try to make each build a little better than the last.
And most of all, don't forget to keep it fun!
KitMaker: 306 posts
Posted: Tuesday, October 30, 2018 - 03:18 AM UTC
As always Tim, your wisdom is always appreciated.
Love seeing new posts on muh threads.
UPDATE: Couldn't really use the AB last night. I am getting my house painted and they sealed up the window I use for ventilation. So I will have to stay preoccupied with building sections and prepping for paint.
Looks like I need some more super glue.
Posted: Tuesday, October 30, 2018 - 04:25 AM UTC
Charlie,
I found that you have to sand the CA right away before it cures otherwise it will be so hard that sanding it will be quite a chore. I left a patch sitting overnight before sanding and I ended up using a metal file because it was like sanding glass.
KitMaker: 306 posts
Posted: Tuesday, October 30, 2018 - 08:39 AM UTC
I might have to find another clearance model and try this trick.
I am tellin ya, after today I am dying for some 1/700 therapy.
KitMaker: 2,877 posts
Model Shipwrights: 2,304 posts
Posted: Wednesday, October 31, 2018 - 08:35 AM UTC
Watching with interest Charlie... always tricky to match up hull halves like that...
KitMaker: 306 posts
Posted: Wednesday, October 31, 2018 - 10:09 AM UTC
It is the current bane of my existence, Russell. I am learning to live with it.
KitMaker: 306 posts
Posted: Monday, November 05, 2018 - 03:59 AM UTC
Morning gents, got some work done this weekend:
Used up all of my flat black:
While that was drying, I went to work building sub assemblies and sanding down little bits and pieces:
And I am so proud of myself!! I managed to scrape off most if not all of the molded on chains for the anchors!! I got a tiny chain with my wooden deck so they needed to go!
Then I got to spray some 50/50 Hull Red and Flat red
At this point, I kind of slowed down and to let everything dry and set up. Some tiny parts we got here and I can't imagine doing another scale. The smallness is very nice.
Thanks for looking guys. Next I have to figure out how to make an even line for the white at the top of the ship.
Posted: Monday, November 05, 2018 - 09:06 PM UTC
Some real nice progress Charlie
KitMaker: 306 posts
Posted: Tuesday, November 06, 2018 - 03:06 AM UTC
Thanks, Russell!!
KitMaker: 306 posts
Posted: Monday, November 12, 2018 - 03:38 AM UTC
Made a small amount of progress this weekend but got stuck on part of the assembly.
Got all muh lifeboats cleaned and ready for paint:
I will tell ya: Get yourself some of these little paper cups from a burger joint. They are life savers:
Got a parts forest for the upcoming paint job:
And masked off the hull to paint before slapping on the wood deck:
Problem I had:
You can see the instructions show the rear superstructure and the assembly. Those two rear posts are waaaaaaaaaay too tall. I am wondering of I have to cut them down to size or what. Anyone else build this Arizona have any tips?
