Ships by Class/Type: Cruisers
1/350 Kleiner Kreuzer Emden - Tsingtau 1913
Black_sheep
KitMaker: 537 posts
Model Shipwrights: 331 posts
Posted: Friday, October 05, 2018 - 11:37 PM UTC
As I have had two days off work I was able to continue with my Emden. I glued on some Details at the outer ships hull and started with some etched superstructures at the ships middle part. So far the progress:
I am still unsure how to continue - prebuild as much as possible of the pe-structures first and paint them later before Installation at the ship or build and glue them on first and paint them altogether later...
Anyhow first needed to be the guns of the tween decks get some paint on. Therefore I showed a comparison of the protected and unprotected main guns between the excellent Shapeways products and the ships plastic guns:
In german we say there is a difference "like day and night".
Black_sheep
KitMaker: 537 posts
Posted: Friday, October 05, 2018 - 11:46 PM UTC
Two questions for the educated audience:
1) where can I get those blackened anchor chains? (why does the usual aftermarked companies who sell the veneer decks include just the brass colored chains?!) Or can I blacken my chains by myself in an easy way without painting? Painted chains will loose their primer color very soon I learned the hard way.
2) I desperately look for Northstarmodels 350070 tightening screws and eybolds in 1/350 for this build but it seems no one carries them; even Northstarsmodels have them out of stock for quite some time now. Some tips were to find these?
Thanks for your help in advance!
KitMaker: 1,034 posts
Model Shipwrights: 571 posts
Posted: Saturday, October 06, 2018 - 02:18 AM UTC
Thomas,
I paint my chains but you can try putting those bass chains in gun bluing to turn them black. Have you tried you-tube for how to videos on coloring chains. I believe I have run across several in the past.
The photo-etch superstructure pieces in your photos, did you glue them together or solder them? I was just wondering how you got the corners so square?
Found the turnbuckles at this hobby shop on line; https://www.ssnmodellbau.de/Photoetch-14/Photoetch-1-350/North-Star-Models-99/?page=3. I believe for 6.5 euros.
KitMaker: 1,826 posts
Model Shipwrights: 1,393 posts
Posted: Saturday, October 06, 2018 - 12:12 PM UTC
Tim, extra for you - just in case you will come one day as a guest to us and crouching down in front of my Emden and stirring around with a penlight...
Thanks Thomas! Though I may make fun of you, I too have gone down that road of detail madness:
May your interiors be more visible than mine!
KitMaker: 3,855 posts
Model Shipwrights: 146 posts
Posted: Saturday, October 06, 2018 - 05:40 PM UTC
If you want to go down the road of modelling madness, buy enough figures to have every station manned for battle.
I did a Z-32 in 1/350 with 86 crewmen at their battle stations. Still... better a full crew than no crew.
Tojo72
KitMaker: 4,460 posts
Model Shipwrights: 252 posts
Posted: Saturday, October 06, 2018 - 11:59 PM UTC
Hey Gary,did you ever see this one,talk about madness,but very impressive.
https://m.youtube.com/watch?v=wggei32XrLo
Posted: Monday, October 08, 2018 - 10:44 PM UTC
Hi Thomas!
looking good!
FWIW I paint my anchor chains. I use enamel paints so don't experience the paint flaking off.
Just a head's up on those printed parts: They're nylon and it doesn't take too well to paint, so be careful with them...
Last but not least, don't burn out adding detail to areas that wont be seen-just my 2cents
Black_sheep
KitMaker: 537 posts
Posted: Sunday, October 14, 2018 - 05:47 AM UTC
Thomas,
Ok I will try to darken my chains with vinegar. No idea if this will work.
Until now I didnīt used soldering, just because I donīt own that Equipment. But one day I will try that too. All parts are just glued. A proper bending tool is very helpful here though!
The turnbuckles in this shop are already gone. I did checked it before. But thank you for your efforts
Black_sheep
KitMaker: 537 posts
Posted: Sunday, October 14, 2018 - 05:48 AM UTC
Gaz may I see a pic of your Z-32? I would be very interested to see it. Must have quite some work to paint an place such a lot crew members.
Black_sheep
KitMaker: 537 posts
Posted: Sunday, October 14, 2018 - 05:51 AM UTC
Hi Thomas!
Thanks for that tip my friend, I think I will prime them first with a enamel color and then we will see how things are going.
You are Right about the detailing of the guns under deck. I will not continue the detailing of These compartments as you can barely can see anything there. Just the protruding guns will be the eyecatcher.
Black_sheep
KitMaker: 537 posts
Posted: Sunday, October 14, 2018 - 06:03 AM UTC
Ahoy, its update time again! Although there is maybe not that much to see as expected (hey the ship is small) I really was busy with replacing all these plastic compartments with the etched parts of EDUARDīs Part 1 set. And I already used about 75% of it now.
The most tricky part was to get the two differend ellipsoid shape of both the armored bridge and the usual Bridge. I heatened the photoetched parts and this allowed me the bending over a drill and get the shapes as I needed. The upper bridge compartment is not even with its upper deck surface. Therefore I had to make me a small distance ring out of styrene between the floor and the sidewalls. It has to get cleaned up than there will nothing of it to be seen later. Until now I am happy about that build.
Complete view of the ship dry fitted:
Frontal view of the bridge:
Backside view of the Bridge - there are still a lot parts missing. Actually I will need to paint the interior first before I glue everything together:
front midship:
aft midship:
Black_sheep
KitMaker: 537 posts
Posted: Sunday, October 14, 2018 - 07:25 AM UTC
Out of fun I built the kitīs simplified plastic bridge just as a comparison for my new photoetched bridge compartment. Already a big difference eh?
Posted: Sunday, October 14, 2018 - 09:00 AM UTC
HI Thomas,
That PE certainly looks better than the plastic, my friend. I'm really looking forward to seeing this ship come to completion. I don't think I would ever try it without the PE and I really don't like much PE.
I generally don't put my photos in another persons build logs, but since you asked I'll do so. They are old photos and not very good, but I hope they give you the ideas you seek. They are meant to show the ship at the battle of Ushant, 9 June 1944.
Once done I took some "mood shots" with a heavy-weather background photos:
I would have taken fresh photos today, but the model has grown fuzzy with dust over time. Hope you like.
KitMaker: 1,099 posts
Model Shipwrights: 788 posts
Posted: Monday, October 15, 2018 - 09:18 PM UTC
Caught up on this Thomas. Great work with the PE which as always adds so much more detail to a kit, especially these older ones.
Posted: Monday, October 15, 2018 - 10:09 PM UTC
Looking good Thomas
Certainly the brass is a massive improvement over the styrene parts
KitMaker: 6,131 posts
Posted: Monday, October 15, 2018 - 10:30 PM UTC
Very nice work with the Etch Thomas, This looks like one of Eduard better ship sets.
Following along with interest, and getting very tempted to have a got at one of these myself.
Black_sheep
KitMaker: 537 posts
Posted: Saturday, October 20, 2018 - 05:04 AM UTC
@ Gaz: very nice looking ship you have there and the crew give it a very lifelike appeareance!
@ Michael and Simon: Welcome aboard mates. These etched sets are really a pleasure until now and will change the look of the ship drastically later (I hope )
Black_sheep
KitMaker: 537 posts
Posted: Saturday, October 20, 2018 - 05:17 AM UTC
A small update about my work of yesterday and today:
First I did sprayed the Linoleum decks with Mr. Color H37 wood brown
After letting the Color drying over night I masked off all floor areas
Then I did sprayed the inside walls, all the shapeway guns and the frontal upper gun sockets in Mr. Color 69 offwhite, the anchor chain area (donīt know the exactly nautical designation about this) and the bollards in black and the waterline mark at the shipīs outside wall in anthracite
After peeling off the tween decks mask you can see how nice the linoleum floor will look from outside later
Next step will be a wash and installation of the tween deck guns and glueing the upper deck with the ship.
Harbor workers dismissed for today!
Posted: Saturday, October 20, 2018 - 06:27 AM UTC
Nice work! When I built this Emden when it came out all those years ago (1990s?) I thought to open up the casemates, but didn't. It is more work, but you clearly made the better choice!
Posted: Saturday, October 20, 2018 - 07:06 AM UTC
Thomas,
Agree, nice work on the decks. Its a lot of masking but well worth it.
Posted: Saturday, October 20, 2018 - 08:47 AM UTC
Thomas,
Nice work! I like the inner decks painted with the linoleum.
Black_sheep
KitMaker: 537 posts
Posted: Saturday, October 20, 2018 - 06:10 PM UTC
You can still make it with itīs available sister ship DRESDEN . I bought the dual set cheaply from Ebay. Now I really think about making the sister ship later in its gray livery steaming through relentless patagonian waters...
Posted: Saturday, October 20, 2018 - 09:04 PM UTC
Nice work Thomas,
Masking is not my favourite sport, by some distance.
Posted: Monday, October 22, 2018 - 08:29 AM UTC
Great to see some colour going on Thomas... Looking forward to the big reveal after the masking is removed-always my favorite part of the process
Tojo72
Posted: Monday, October 22, 2018 - 10:35 AM UTC
Just a little,that’s a lot of metal and it looks great.
