Tools & Supplies: Airbrushes
Talk about airbrushes.
H&S needle compatability
pod3105
Waterford, Ireland
KitMaker: 358 posts
Posted: Sunday, July 22, 2018 - 07:34 AM UTC
Folks, can anyone tell me in the 0.15mm needle set is compatable with the H&S Ultra a/b?
PRH001
New Mexico, United States
KitMaker: 530 posts
Posted: Sunday, July 22, 2018 - 11:20 AM UTC
The H&S Ultra uses a single piece aircap versus the two piece style used on the Infinity or the Evolution. I seriously doubt that you would see any improvement in spray pattern if the nozzle and needle fit due to the size of the exit orifice. With, that said, I donít own an Ultra, so I cannot give you a concrete answer.
Hope this helps,
Paul H
Vicious
KitMaker: 1,365 posts
Posted: Sunday, July 22, 2018 - 11:31 AM UTC
The Ultra is a simplified Evolution/Infinity for beginners so in theory even if H&S does not officially say it is perfectly interchangeable nozzle and needle, but I'm not 100% sure if the aircap is compatible.
Try to contact this shop, the owner is very kind and always ready to help and has the whole range of H&S
https://www.modellingtools.co.uk/needles-nozzles-aircaps-139-c.asp
pod3105
Waterford, Ireland
KitMaker: 358 posts
Posted: Sunday, July 22, 2018 - 07:59 PM UTC
Paul H, Viscous,
thank you both very much for your responses. Very helpful.
Regards
Pod (the other Paul H)
Vicious
Posted: Sunday, July 22, 2018 - 08:27 PM UTC
in the infinity/Evo the spraycap of the 0.2 use the same cap of the 0.15 the problem for you is if fit the Ultra cap or if you can swap with the infinity one
