FLATTOPS CAMPAIGN THREAD
trahe
KitMaker: 1,139 posts
Model Shipwrights: 109 posts
Posted: Saturday, June 16, 2018 - 10:24 AM UTC
View inside elevator 1 doors at parked F18Cs.
View inside elevator 3 doors at replenishment stores and forklifts. Aircraft servicing equipment and a C3 COD also visible.
I used an LED strip for lighting. Overhead (ceiling) made from sheet styrene with square holes cut to accommodate lights.
Bigrip74
KitMaker: 4,794 posts
Model Shipwrights: 37 posts
Posted: Saturday, June 16, 2018 - 01:43 PM UTC
Thomas, OUTSTANDING work.
KitMaker: 6,487 posts
Model Shipwrights: 6,058 posts
Posted: Saturday, June 16, 2018 - 08:08 PM UTC
Very effective Thomas.
Greta view inside the hangers.
trahe
Posted: Sunday, June 17, 2018 - 08:26 AM UTC
Thanks! Hoping to get this sucker finished up soon! Working on tow tractors and fire trucks.
Posted: Tuesday, June 19, 2018 - 08:59 AM UTC
Quick update from the weekend.
The brass structure under the bow, well the big bits anyway.
How it looks dry fitted in place.
more soon.
trahe
Posted: Tuesday, June 19, 2018 - 01:56 PM UTC
Si, that looks great! You have incredible patience working all that brass! Are you going to have to paint in sub-assemblies?
trahe
Posted: Wednesday, June 20, 2018 - 01:59 AM UTC
Bow on with aircraft spotted on deck. Work to be done: add ordnance jettison ramps, add stern boat dock, add tow tractors and fire trucks, re-do signal flag lines with thinner line (maybe add signal flags), add US Flag.
Posted: Wednesday, June 20, 2018 - 07:01 AM UTC
Thank you Thomas,
Yes I am, the main hull, and the three sections of the flight deck will be painted separately, and then brought together.
Posted: Wednesday, June 20, 2018 - 07:03 AM UTC
Hi Thomas,
Looks very impressive, a nice line up on the deck.
Bigrip74
Posted: Thursday, June 21, 2018 - 02:27 AM UTC
Thomas, she looks good and I love the flight deck full of a/c.
A little progress on my Lexington.
Bob
KitMaker: 1,476 posts
Model Shipwrights: 893 posts
Posted: Thursday, June 21, 2018 - 05:54 AM UTC
Bob,
Nice progress on your Lady Lex.
Posted: Thursday, June 21, 2018 - 07:02 AM UTC
Lady Lex is coming on very nicely Bob
trahe
Posted: Thursday, June 21, 2018 - 01:50 PM UTC
Bob, Lexington looking pretty good. Is that 1/700 scale?
Bigrip74
Posted: Thursday, June 21, 2018 - 02:03 PM UTC
Thomas, yes it is 1/700. I thought that I would start small.
Bob
trahe
Posted: Saturday, June 23, 2018 - 06:38 AM UTC
Stern boat dock under construction. I noticed the name must have slipped while drying, so I will have to re-do that...
Ordnance jettison ramps installed
Deck vehicles getting added
Bigrip74
Posted: Saturday, June 23, 2018 - 07:48 AM UTC
Thomas, the Reagan looks really good and I am amazed at the panel lines on the A/C.
Bob
KitMaker: 208 posts
Model Shipwrights: 208 posts
Posted: Saturday, June 23, 2018 - 07:59 AM UTC
I built the Fujimi Lexington, it seems like a lifetime ago, but there are a couple of things I want to bring to your attention, based upon my memory of the kit.
The hill seems to my eye to be to high from the waterline plate to the flight deck. You may want to check that out with scale drawings before you get too far along. Remember Lex and Sara started life as battle cruisers, and as such design allowances had to be made to convert them to carriers.
The second thing is the stern round down on the flight deck. The round down itself is all steel and not covered with planking as it is (perhaps was) on the model. That would have to be sanded smooth. Fujimi also has the center line molded all the way to the extreme rear of the flight deck. That should also be removed along with the planking on the round down.
During this time frame you are shooting for I have absolutely no idea if Lexington had any flight deck markings. I have never seen a photo that shows any, but that does not mean they were not there. Don't know what to say other than that. Were it me though, and seeing is how these marking areas are molded in, I would probably use them. Don't think anyone would be in a position to say you were wrong.
Other than that though both the Fujimi and Ming kits are well suited for a Lexington in the late 41 to April 42 configuration. Never did understand though why the model company would not provide the option of 8" guns or quad 1.1 inch guns and let the modeler decide.
KitMaker: 208 posts
Posted: Saturday, June 23, 2018 - 08:31 AM UTC
Bob: Following along with that height of hull issue I mentioned above, remembering that the Fujimi Lexington was released very early by the 1/700 scale waterline conglomerate of companies, I believe that where the red waterline plate is affixed to Lex is where the red portion of the under hull would be, as opposed to the boot top location on that Enterprise you have. Assuming that is so, then I would not try any radical hull surgery on the hull to make it lower. I would simply put the boot topping above the waterline plate, and if you intend to mount Lex in a sea base no one would know any difference, as the difference would not show.
trahe
Posted: Saturday, June 23, 2018 - 01:57 PM UTC
Bob
Thanks Bob. The Trumpeter aircraft come with nice engraved panel lines. All I had to do was a pin wash to bring them out.
Posted: Saturday, June 23, 2018 - 08:50 PM UTC
Nice work on The Stern boat dock Thomas, the aircraft and the vehicles really add to the deck too.
Looks great.
petbat
KitMaker: 2,390 posts
Posted: Sunday, June 24, 2018 - 03:05 PM UTC
Guys, Not sure if you are interested or not, but I noticed there is no award ribbon for this build. I was playing around making some for other builds and thought I would stretch and do a couple for this build too. Up to you if you want to use them or come up with your own.
Flat Tops GB
KitMaker: 2,082 posts
Model Shipwrights: 1,521 posts
Posted: Sunday, June 24, 2018 - 03:11 PM UTC
For what its worth, I like this one:
Posted: Monday, June 25, 2018 - 06:06 AM UTC
Agree with Tim,
Better than anything I have been plating with.
Opinions please?
PasiAhopelto
Uusimaa, Finland
KitMaker: 362 posts
Posted: Tuesday, June 26, 2018 - 05:09 AM UTC
I like that one too.
And time to get this started:
Cadeus
KitMaker: 144 posts
Model Shipwrights: 139 posts
Posted: Wednesday, June 27, 2018 - 11:29 PM UTC
All these builds are looking good, Ill have an update on the independence CVL-22 soon. Have completed a lot but I am horrible about posting updates to logs.
