Scratchbuilders!
Built a model or part from your own materials lately?
Hosted by Mike Kirchoff
Material for very thin leather straps?
Cantstopbuyingkits
European Union
KitMaker: 1,988 posts
Posted: Saturday, December 02, 2017 - 07:05 AM GMT+7
You could tracing paper, it's less likely to break than regular paper.
Scarred
KitMaker: 656 posts
Posted: Saturday, December 02, 2017 - 04:03 AM GMT+7
Try using aluminum foil duct tape. It's thicker than regular foil and doesn't tear as easily.
I was playing with this stuff last year and it might work. The adhesive is strong, it's relatively soft, very pliable, cuts easily with scissors or blade.
sgtreef
Oklahoma, United States
KitMaker: 5,825 posts
Model Shipwrights: 15 posts
Posted: Saturday, December 02, 2017 - 01:18 AM GMT+7
Can try the stuff these folks sell, not bad ordered the two strap deals real thin.
http://hgwmodels.cz/en/52-135-scale
Jeff
warlock109
Utah, United States
KitMaker: 160 posts
Posted: Thursday, November 30, 2017 - 12:16 PM GMT+7
KitMaker: 1,779 posts
Model Shipwrights: 74 posts
Posted: Thursday, November 30, 2017 - 08:01 AM GMT+7
I just use plain typing paper cut into any length or width I need. It can be bent, folded, folded onto itself, glued, sanded, or painted. Once you get it into the proper position, you can give it a coat of thin cyanoacrylate and it will last forever, and can be further sanded or painted to your needs. Painted up with leather brown, it will look like the real thing. You can mark it up with a sharp pencil to represent perforations for buckles and snaps. I've also used it for US canvas belts and web gear by dampening it, pressing it onto the figure, letting it dry a day or so, then cyanoacrylating it. Then carefully using the tip of a knife, carving grooves to represent the "ribbing", and a very fine drill to represent the eyelets found in US web gear. No special materials needed, other than a sharp Xacto blade and ruler and some thin super glue.
EHAM0624
Noord-Holland, Netherlands
KitMaker: 176 posts
Posted: Thursday, November 30, 2017 - 07:26 AM GMT+7
I use paper coffee filters for straps and belts, depending on how you drink the stuff i guess you can't get them in every country. Robin and Toms suggestion i also use
good luck
justsendit
KitMaker: 2,616 posts
Model Shipwrights: 34 posts
Posted: Thursday, November 30, 2017 - 06:02 AM GMT+7
Lol! I actually got rid of all my cassettes during my last move! If a stray cassette should ever turn up, I'm open to trying it out.
Cheers!🍺
—mike
ayovtshev
#490
Sofiya, Bulgaria
KitMaker: 384 posts
Posted: Thursday, November 30, 2017 - 05:55 AM GMT+7
justsendit
Posted: Thursday, November 30, 2017 - 05:15 AM GMT+7
I have used most of the above, but find lately that my go-to has been Tamiya masking tape. I've used paper in the past, but found it difficult to handle if painted before attaching it, and nearly impossible to thread into PE buckles. Lead foil is nice, as you can roll it to a desired thickness and can easily be shaped over surfaces. Acrylics don't adhere to foil very well though. I keep all of these on hand for various applications.
When using Tamiya tape, I generally stick it to my clothing in order to de-tack it — old school trick. Sometimes a little leftover tack is a blessing though. The tape can also be rolled to a desired thickness — useful for threading PE buckles. For better paint adhesion, a little buffing of the shiny side with sand paper helps.
Cassette tape? … What’s that? Lol!
—mike
#160
KitMaker: 11,218 posts
Posted: Thursday, November 30, 2017 - 03:26 AM GMT+7
I use Tamiya tape, folded over on itself.
Hohenstaufen
KitMaker: 1,957 posts
Posted: Thursday, November 30, 2017 - 01:12 AM GMT+7
I also use champagne bottle foil. However many years ago there was a series in Military Modelling, in which the modeller (I can't remeber who it was) used an old handkerchief, soaked in enamel paint or possibly white glue. When dry it can be cut finely without fraying and "hangs" more naturally than say Plastikard.
120mmSniper
KitMaker: 119 posts
Posted: Wednesday, November 29, 2017 - 11:08 AM GMT+7
Lead foil. A friend from New Zealand gave me some from wine bottles, but that was years ago. No wineries in the US still use lead foil, AFAIK. Not sure where to find it these days, but it is great for an application like yours.
ayovtshev
#490
Sofiya, Bulgaria
KitMaker: 384 posts
Posted: Wednesday, November 29, 2017 - 05:36 AM GMT+7
Try cassette tape.
It cuts nicely and only needs a dab of CA to stick forever.
And as an additional reward- it has the appropriate brown collor
ronbo070
KitMaker: 28 posts
Posted: Wednesday, June 21, 2017 - 07:49 PM GMT+7
If you are talking about the strap on either side they are spring steel wrapped in leather. You could duplicate them with thin strips of metal wrapped in paper tape and paint them accordingly.
The straps were designed to put pressure on the ear flaps and speakers. They were attached to the helmet by a single rivet and could swing out of the way. I hope this helps..
Neo
KitMaker: 756 posts
Posted: Tuesday, April 04, 2017 - 02:30 PM GMT+7
Phil,
Painters tape or masking tape. Hit end w/ super glue and it will never drop off.
KitMaker: 3,365 posts
Model Shipwrights: 56 posts
Posted: Wednesday, March 01, 2017 - 09:44 PM GMT+7
I have the habit of taking things apart to check if there is something useful for modelling inside.
Cables contain copper wires of various thicknesses.
When I disassembled the cable on some broken mobile phone earplugs I found that the shielding consisted of a narrow strip of thin copper foil wound around the wires inside. They were less than 1 mm wide and my thought then was that they would be ideal for safety harness belts.
Another possibility is to use thin copper wire (or aluminum if you can get hold of thin alu-wire). Fasten (tape down the ends) short pieces on a hard (steel plate) surface and flatten them by rolling a steel pipe (or other hard cylinder) along them (press hard).
Copper can be softened, if needed, by heating with a flame.
The rolling will flatten the wire and also make it slightly longer so you may need to adjust the adhesive tapes holding them down. The flattened wire will have rounded edges and be smooth so they willresemble leather straps.
KitMaker: 3,399 posts
Model Shipwrights: 91 posts
Posted: Wednesday, March 01, 2017 - 08:56 PM GMT+7
Phil,
Try aluminium foil. The stuff that comes on Champagne type bottles is a bit firmer than the kitchen kind. Just make sure your knife is very sharp.
Vicious
KitMaker: 1,048 posts
Posted: Wednesday, March 01, 2017 - 04:26 PM GMT+7
I use the foil that seals the tins of Milo....yes the chocolate powder... ....it is thick enough to resist shear and easy to work, but in the other hand is very fine, or masking tape Tamiya.
Phil5000
New Zealand
KitMaker: 125 posts
Posted: Wednesday, March 01, 2017 - 03:08 PM GMT+7
Hi guys. I'm working on some US tankers WW2 1/35 and I want to make the leather straps for their helmets. I would just cut up some paper strips but the paper just frays or tears if you cut it that small. What else could I use? Do they do plastic sheet that thin?
