HMS Hood 1941 - Trumpeter 1/350 + Lion Roar
KitMaker: 2,036 posts
Model Shipwrights: 1,713 posts
Posted: Monday, August 21, 2017 - 04:00 PM GMT+7
Thanks Russ!!
Very small steps indeed, but anything is better than nothing. I hope I get that PE fret in place as desired...
You can do it Jan! A bit of annealing to soften it up, then get the folds just so, then hit it with CA and accelerator before it moves.
KitMaker: 1,442 posts
Model Shipwrights: 1,439 posts
Posted: Sunday, September 10, 2017 - 04:59 PM GMT+7
Okay, here we go -
I managed to squeeze some bench time in before office a few times, and actually last weekend was not to bad - a break during my moving places, and luckily I decided to move my shipyard late, so as to have a little distraction whenever time allows.
So a lot of small stuff, North Star RN bridge equipment and searchlights (10 and 20 inches), and even the smallest parts need construction and PE...
Here some impressions:
Basic parts for a 20" searchlight
building:
Next to the kit's part:
Nice improvement I would say.
The 10" one:
And just a few random pics of other small stuff, before and after painting. My improvised closed railing as well.
The HACS Mk III (Shapeways):
Altogether
Work on the closed railing - filling - sanding and repeat. Not perfect, but I'll leave it at that before I risk havoc...
Sanded down bullseyes replaced
And several small stuff shipped. Pictures at random pre/after touch ups. And a lot more touch ups required...
And finally - another level added to the forward superstructure. Next will be more touch ups, and possibly a little filling and sanding.
So much for now, I should post some final pictures before I start moving my shipyard, but I don't expect much progress. We will see...
Thanks for looking in,
Posted: Monday, September 11, 2017 - 01:25 AM GMT+7
Wow Jan!
What an update! Your nano engineering skills on those searchlights are exceptional! It's those little details that make a ship pop and draw the viewer's eye in! Great work mate!
good to see also that the dockyard is still up and running till your move is complete! Very substantial progress there and will reap much rewards as the bridge tower builds up!
KitMaker: 853 posts
Model Shipwrights: 655 posts
Posted: Monday, September 11, 2017 - 09:00 PM GMT+7
Everything Russ said, especially good to see the dockyard back in full swing.
Posted: Sunday, September 17, 2017 - 05:02 PM GMT+7
Russ and Michael,
thank you very much for still sticking around, following and for your kind comments!!
Well, I wish the yard would be in full swing, however, it's not - it is just a temporary uprise in activity before the whole yard will move.
And here's the final update from the current location, I squeezed in some bench time between packing boxes and preparing my move, that will take place over the next four weeks.
God thing is that there is not so much stuff to move around this time, still plenty though...bad thing is I have to do it all by myself and my car, on the weekends. So one trip per weekend, that's why it takes four weeks...so glad when I'm done with that...
But something more positive - a little progress...
That's how I left her last week
I figured that some small parts are missing, that don't show on any instructions - in particular rails around the ladders.
Two lengths of Lion Roar railing (which is extremely fragile) bent around one 'tooth' of my bending tool that fortunately has exactly the right size.
And on to the next level of the bridge.
However, that looks wrong, there should be railing facing forward and some ladders to the upper area. Well, I do know it's not correct as I did it, some gizmology, but I think it's better than before.
Started on the outer breakwaters, more supports needed, only the middle one installed so far.
On the lower bridge only some defectors and the carley floats missing (and some railing). Slowly getting there.
Here's where things are at the point where I stop building but start moving my HMS Hood and the whole shipyard. So next update from a new shipyard (or the old one in a different place), probably not before late October / early November.
So much for now, and I hope you'll still be following in a few weeks!!
Posted: Sunday, September 17, 2017 - 11:59 PM GMT+7
good to see you still chipping away at her Jan.
And a nice touch too with the railings around the ladder openings. I think the only time I've seen an aftermarket company mention them has been with Eduard, although i could be wrong?
Good luck with the moving, hope nothing gets lost or broken along the way and we all will be waiting for the next update from the new, old, "Jansen Shipyard"
Posted: Monday, September 18, 2017 - 03:56 PM GMT+7
Hi Russ
and thanks a lot!!
- I do have the Eduard set for the Hood (as the older Lion Roar - but the Ed set is quite ancient, too, for that matter - so they may have introduced the rails around the ladders later on)
Work on dismantling the shipyard will commence soon, and the good Hood herself will move either this Friday or next week...I really hope she'll get there unscratched. She will have the passenger's seat all for herself, gently buckled up - the same way as I moved HMS Repulse from Brussels to here over three years ago...
KitMaker: 1,257 posts
Model Shipwrights: 1,109 posts
Posted: Tuesday, September 19, 2017 - 06:25 AM GMT+7
Jan,
I know I have been absent for quite a while but I have been following along as I could. Amazing work. My desire is to one day reach the level of detail and care that you have achieved with this build. Simply amazing
Good luck with the move and as Russell said, I do hope everything makes the transition in one piece.
kpnuts
KitMaker: 803 posts
Model Shipwrights: 286 posts
Posted: Wednesday, September 20, 2017 - 07:02 AM GMT+7
Great work going on here.
KitMaker: 28 posts
Model Shipwrights: 21 posts
Posted: Friday, September 22, 2017 - 05:43 AM GMT+7
Awesome stuff, man. Can't wait to see it all finished. Good luck on the move!!!!
bkilly
New Zealand
KitMaker: 3 posts
Posted: Sunday, September 24, 2017 - 03:21 PM GMT+7
Hi Jan,
This is a first for me since I have only just [past year] started ship building. I have searched many sites and can only congratulate you on the patience and standard of your build of the Trumpi 1/350 Hood.
I too have bought this kit and having followed you from the beginning [thus discovering problems with the kit], I have bought after market products to enhance the model.Gold Medal Models; WEM; Pontos,North Star and Shapeways to name a few.
I noted you have Shapeways ships boats set, and having scrolled through their website I cannot find boats relating to HMS Hood. I sent an enquiry to Shapeways customer service and they could not help me. My question is: what boat set did you buy and what was the reference number?
I hope you can assist, and keep up the excellent modelling.
Kind regards
Brian Kilonback Auckland New Zealand address@email.com
Posted: Monday, September 25, 2017 - 04:34 PM GMT+7
Hi Dave, Ken and Charlie,
thanks a lot for your kind comments, Charlie, welcome onboard and thanks for joining in!!
A little good news - sorry, no progress - but a least HMS Hood arrived home safely, she's resting on a shelf in my office (next to HMS Repulse, HMS Prince of Wales, HMS Belfast and others) for the time being, what was (and will become again in a few weeks) my model shipyard is entirely blocked with boxes and stuff from moving...
So I need to ask you some more patience before work will re-commence.
Brian -
welcome on board, thank you very much for your kind remarks and thanks for following my build!!
As for your question, there are a couple of sets on Shapeways for different RN Boats, quite amazing that they could not point you in the right direction. Maybe it is because they are not labelled 'Hood' and all they do at the customers service is check their search engines. Well, I'd imagine not so many warship enthusiasts or shipwrights there...
So here are four different sets, you get them with or without mounts:
https://www.shapeways.com/product/759LRL8QR/1-350-ww2-rn-boat-set-1-with-mounts
https://www.shapeways.com/product/AG93QYAS3/1-350-ww2-rn-boat-set-2-without-mounts
https://www.shapeways.com/product/V8PUJWYJL/1-350-ww2-rn-boat-set-3-without-mounts
https://www.shapeways.com/product/GSJ4LL96U/1-350-ww2-rn-boat-set-4-without-mounts
For my 1941 version I picked set 1 without mounts and sets 3 one each with and without mounts; that, to the best I could get from my references, gave me the needed boats in sufficient quantity. For an earlier version you will need to look into the other sets for the steam barges etc., which, as far as I could find out, were removed some time before the battle of Denmark Strait. I might stand corrected on this one, if anybody has better information. If so - please do!!
I hope that helps!
- and, best of luck and fun and enjoy your HMS Hood project, sounds like a great project with all the stuff you got!!
Cheers for now,
KitMaker: 28 posts
Posted: Tuesday, September 26, 2017 - 04:15 AM GMT+7
Thanks man!! Glad to be aboard!! The fleet looks stunning!
KitMaker: 853 posts
Posted: Tuesday, September 26, 2017 - 06:29 PM GMT+7
Indeed the fleet does look stunning. You need to stand back and give us the wide angle view of the whole.
bkilly
New Zealand
KitMaker: 3 posts
Posted: Thursday, September 28, 2017 - 09:30 AM GMT+7
Brian -
I hope that helps!
Cheers for now,
bkilly
New Zealand
KitMaker: 3 posts
Posted: Thursday, September 28, 2017 - 09:37 AM GMT+7
Hi Jan,
Thanks for the 'heads up' on the Hood ships boats. Have ordered three sets, and since I am modelling the 1941 version did not go for the steam types.
Your shipyard looks amazing hope I can achieve similar results over a period of time.
Cheers Brian
Posted: Sunday, October 01, 2017 - 08:30 PM GMT+7
All right then - off topic:
Upper shelf is the later builds, all of them I have shown here, at least briefly: HMS Repulse, HMS Prince of Wales (no build log but pics), the current build HMS Hood, the two subs IXC and VII C, HMS Belfast, and the Graf Spee (no Build log on MSW).
Lower shelf is a fleet of Heller 1/400, all OOB, most painted with a hairy stick and marking my re-entry in the hobby of ship modeling several years ago. They were quick and dirty fun builds. Comparison between the Heller Hood and my current build is quite remarkable, as is the comparison of the two PoW`s and Graf Spee`s...
Posted: Sunday, October 01, 2017 - 10:30 PM GMT+7
off topic, maybe, but soooo good!
KitMaker: 1,356 posts
Model Shipwrights: 1,036 posts
Posted: Monday, October 02, 2017 - 03:58 PM GMT+7
Hi Jan,
There's room for both the AMS ("Advanced Modeler's Syndrome") builds that have everything but also seem to take forever and the quick and dirty fun builds too. I'm sure you agree - as long as we're having fun, it's just right!
Nice collection, Jan!
Posted: Sunday, October 08, 2017 - 03:58 PM GMT+7
Thanks Russ
and Tim,
Hi Jan,
I agree 100%!!
All of the model shipyard has been successfully moved but is still in multiple boxes. This moving isn't actually fun, but I am forced to re-organizne everything and thats certainly a chance. The yard was getting more and more chaotic, with a myriad of things eating up space that I'm never going to use again. And the compressor received a long overdue und well earned cleaning and fresh oil...
KitMaker: 853 posts
Posted: Sunday, October 08, 2017 - 08:56 PM GMT+7
Thanks for sharing the fleet Jan
KitMaker: 4,946 posts
Model Shipwrights: 4,535 posts
Posted: Saturday, October 21, 2017 - 07:12 AM GMT+7
Hi Jan,
Great work on the Hood, she is coming on so well.
Love your fleet too, some impressive work there mate.
Posted: Sunday, November 12, 2017 - 05:40 PM GMT+7
Hi all,
thanks for still bearing with me...all is progressing but slower than planned.
However, a small sign of life - the shipyard is slowly coming back online. But work has not commenced again yet, and I have some more real-life busy weeks ahead of me...
Here's my men cave - somehow it feels as if my improvised places were bigger than that one. Well, it's moving back home after five years, and during those years my idea of modeling has changed significantly - and with it my demands for the shipyard. Will see that I get everything squeezed in there and find a working routine...
Cheers for now,
KitMaker: 853 posts
Posted: Sunday, November 12, 2017 - 08:18 PM GMT+7
Very tidy set-up Jan. Good to see the critical supplies to the right of you. I hope those shelves are robust
Posted: Sunday, November 12, 2017 - 10:24 PM GMT+7
Good to see the shipyard back on line Jan!
And like Micheal says, it's good to see you've got the essential supplies close at hand!
